MLars
Hey guys, almost time to winterize my 787 GTX. Just have a couple questions:
1. When changing pump oil, all I need to put it back on is a new o-ring and blue loc tite for the 3 bolts right? Or is it better to put some sealant on the o-ring?
2. For antifreeze, should I do a 50/50 mix or 100% antifreeze? There seems to be some controversy over this.
3. In the shop manual, it says to spray their Bombardier Lube into the engine. Why would I use this instead of fogging oil?
4. When testing the pump cone pressure, do I need to buy a $50 tester? Or can I just use another gauge, like an electric pump with a psi gauge? What size fitting would I need?
Thanks for the help guys.
