As Popps said, the check valves will typically cause you to run lean not rich like your plugs show. If the inlet check valve doesn't work the tank will build a vacuum and starve the carbs for fuel. If the pressure relief is bad it can cause the carbs to dribble when sitting from the fuel pressure that can build up causing hard starting and flooding.
