1997 GTX off season rebuild start.
Satisfied with oil injection study so on to the next endeavor.
This concerns the lubrication of the RV gear cavity. Lurked around a few of the Rotax/aviation forums & also called a few maintenance shops that specialized in Rotax engines in the aviation applications. There was one particular "mod" I'm going to explore but there's a disconnect that I couldn't pin down. The circulation of oil in the RV gear circuit.
Is there any circulation occurring @ all in the circuit, be it negligible but movement none the less?
No circulation in the RV
I'll start there. Knowing this, the "flyboys" workaround is going closed loop, some with a small coolant M/C tank dedicated to RV oil (same injected oil) so as to monitor level. A regimented pm involves gently purging the oil & sent out to be analyzed for metal particulates. Granted this might seem extreme but their 2K feet in the air = Ouch. Dead pilots can't rebuild.
Myself, "leaning" towards closed loop with small vented tank & a more laxed pm regiment. Placement of tank height within hull in relation to oil cavity level will require some thought = ouch.😳.
Here's a couple few of pics of anxiety's belayed. No leaks @ grommet after 16 hrs.
Thanks for the info.
