Front seat modifications - 98 Sportster 14'
Jeb911
I'm not sure what the official name is for the 14' 98 Sportster but this is what I'm referring to...
My Sportster has a removable cushion in the front that snaps to the boat. I was curious if anyone has modified the area under the cushion to maybe accommodate a cooler or for dry storage.
Does anyone know what's directly under the fiberglass where the cushion attaches?
in my 95 there is nothing under there, but i would be worried the backing on the seat would hold any weight over the huge hole you would make.
the only thing that is there is the wiring that goes to the front lights on my boat, but i'm sure those could be push out of the way. not sure if the 98 is anything similar or not. just chiming in.
I would build a bucket to fit in the opened slot just like the bucket that fits in the dry storage compartment. The front seat would be removable. I would reinforce the seat so that the weight is distributed evenly. I may even split the new storage area in half allowing a center support area as well. I just think it is a waste of space and this boat doesnt have enough storage.
It was on my "too do" list, then I sold the speedster.
I would think you could make the hole 6x6 or some size and make the compartment underneath the entire seat area...
Use foam and fiberglass mat to make something, or depending on the space spray foam and mold it, lots of options...
That's a good idea. I can probably cut a hole then insert 4 corner pieces with L shapes on the bottoms and fasten them from the top. From there, I can attach supports from the corners and install slats for the bottom. I will then have a sturdy frame. Then, I can lay the fiberglass mat in and roll on some resin. I might even install a drain + hose in case I want to put ice in it. :) Sounds like a new project.
Ship shape tv had an episode on build coolers.. :)
