F1 fuse fix didn’t go well
Cgod14
8C0AFE43-99AE-44EA-B718-170648D02E4A.jpegPulled baffle on 1997 gti and soldered F1 fuse like other threads explain. It was my first time soldering so it wasn’t pretty but it seems functional. Before I did it my Gauge showed completely empty and now I put the key on to test it and it’s on full no matter where the float is. Picture attached any suggestions?
You soldered one side of the board to the other... Heat it up, wipe off the solder and look at the board again. Your mistake should be easy to see.
It looks like that board has corrosion at the reed switches. It might just be a bad board that can't be saved. I have not seen them with corrosion like yours has.
