PASTFAST03
I just purchased a 1999 seadoo chaleneger one of the motors has perfect compression amd the other motor has compression 145-150 on the back (rearof boat) cylinder and the front has nothing. Any ideas
Ok thank you any type of oil?? An when I try to start it it started and shit off and when I tried again it turns over but back fired
my amateur guess is it was run lean and melted a piston.
Ok finally got the top end out of the boat did not remove the whole engine the back piston was a all pitted ad drstroyed. so no I realize gonna be a little hard to remove the pistons. Any help would be greatly appreciated how do I go about removing the pistons eats the easiest way, thanks
