Seadoo Tuner
My 96 SPI engine lost compression on one of the cylinders last summer (suspect crank bearings) so I picked up a used running 587 engine that has sat for a year or more so and am wondering on best options for it and am looking for advice and comments on each option :
1) Pressure test, sand/hone cylinder walls, change top end gaskets, and run it as is.
2) Top end rebuild
3) Split cases to put new outer crank gaskets in in addition to top end rebuild.
Would a light sanding of the cylinder walls suffice or does it need a hone? Hows the cylinder wash look?
Pics of the used 587 engine :
2) Top end rebuild
