1996 SPI Used 587 Engine Swap (With Pics) - Options, Rebuild or Run?
My 96 SPI engine lost compression on one of the cylinders last summer (suspect crank bearings) so I picked up a used running 587 engine that has sat for a year or more so and am wondering on best options for it and am looking for advice and comments on each option :
1) Pressure test, sand/hone cylinder walls, change top end gaskets, and run it as is.
2) Top end rebuild
3) Split cases to put new outer crank gaskets in in addition to top end rebuild.
Would a light sanding of the cylinder walls suffice or does it need a hone? Hows the cylinder wash look?
Pics of the used 587 engine :
cover off pic.jpgfront cylinder pic.jpgrear cylinder pic.jpgrust in cylinder sleeve.jpgcylinder sleeve marks 2.jpg
2) Top end rebuild
View attachment 69020View attachment 69021View attachment 69022View attachment 69023View attachment 69024
#3.
If applicable...
Your correct on new gaskets/seals.
Use the same pistons with new needle bearings & new rings. With new rings, hone, need that cross hatch.
If I can make chicken salad out of chicken sh**, so can you.
Just don't step over a dollar to get to a dime.
You got this.
ps. Chicken salad does have a short expiration date.
I would remove the cylinders and look inside the bottom end, check the crankshaft. The top end is in rough shape so keeping any pieces parts out of the bottom is the goal. If the carb was off the engine, the crank probably looks the same as the top end but good inspection would reveal the condition. I always flush the bottom end really good with diesel, let is sit, rotate the crank many times. Dump it out, blow it out and dry it especially the two little drain holes below the cylinders (I also drip oil into these holes and into the bearing cavity before final assembly) . Before flushing with oil.... I check for bad bearings, especially connecting rod bearings. Then if all is well, I flush with a good amount of two stroke oil and let it sit a few days. I don't replace crank seals unless I see a need to remove the cranks.
If you remove the crank, the process is less time consuming as you can visually inspect all the components and rotate each individual bearing to verify good condition. If you remove the crank, replace the seals. Good Luck !!
Oof... definitely check those crank bearings. If the top end is rusted, i bet the bottom is as well. Complete rebuild will be needed if so. The rust on those cylinder walls looks pretty bad, will probably need at least .25 bore to fully remove it.
One thing about the crank/lower end - its filled with oil and rotating it the crank looks ok (no rust).
The engine was stored in a garage apparently after removal from a seadoo that had a 720 swapped in it.
What kind of hone tool is recommended? Seen a few types that attach to a drill, and heard there's pro's and cons to them.
Inner crank seals are leaking. I wouldn't roll the dice. May as well fix it right and be one. You don't want to go that far and peice meal it. New or rebuilt crank.
Here is a thought, you could ask the previous owner if he poured oil in the bottom end. If not, the inner crank seals are leaking.
Rotary valve cover has a slight scratch on the engine - how to smooth it out/resurface? Heard of people using sandpaper for light scratches. Pics of the rave valve cover :
Scratches are not a problem. Gouges that extend from port to port are a problem. That looks to be in good condition from what I can tell from the picture. You can pressure up the rotary valve cavity pretty easy from that point. Plug the outlet and put an air line on the inlet with a gauge. 5 pounds or so, no more than 8psi. That will let you know if your inner seals are leaking at which point you need to rebuild the crankshaft. Good Luck
