Hey everybody. I was gonna pull my engine to rebuild top end, and to check everything out out of hull. When I'm finished with the top end and check everything and put the engine back in, does it need to be re aligned even if I use the same shims that were in there?
Also, the manual says when removing the engine I have to take off jet pump and both front and rear drive shafts. On another website it has a step by step procedure for removing my engine and they say to just slide the engine forward in the hull and nothing about removing these shafts. Anybody done it that way?
Anyway of making a tool?
