Drive shaft oil leak on fish pro?
Paragon1
Installed the battery today and noticed this inside the hull. Appears that some oil is spinning off the drive shaft and spraying the inside making a nice neat line across the inside of the hull. Is this normal for a brand new ski? Is something shifted out of place? Kinda looks like the shield to the right should be moved left. I’ve owned several boats, never a ski, and the nearest seadoo dealer is 100mi away. Hopefully it’d an easy fix.
Thanks
You ought to check out the fishpro FB group--a lot of posts there. Just go to FB and search for Fishpro.
What you're seeing is the carbon seal. A narrow stripe is normal. A very wide stripe bad.
