I just disconnected my beeper because its not working, my question is i know these elctrical systems are very touchy will it effect my normal opersation untill i get a new beeper thanks.
No, it won't effect the electrical system, the problem is you won't have a warning for low oil, high temp. etc. You can get a replacement, actually better than the original, at Radio Shack. I would get one ASAP.
Thanks alot guys for your help! , well i took the plastics off the jet ski so i could redo the frame pad with vinyl i knew it wasnt working so i just decided to take it out just wasnt sure when i would get a new buzzer and wanted to water test it, also how do you reconnect the radio shack buzzer because of the color code wires i mean is there a certain way or can i just trial and error to see which wire goes to which side? once again i really appreciate all your help as always! alan.
