horizondust
Did following the recommended procedure for clearing water from a flooded engine really cause bearing failure in the crankshaft?
Here are the details:
Accidentally towed '97 XP upside down for a short while resulting in a water flooded engine. Followed instructions for blowing water out by removing spark plugs, cranking, fogging, etc. Twice the engine caught briefly, coughed, and blew water out exhaust. Engine never started again despite another three hours of repeating procedure through 4 battery charges. Gave up and took ski to shop. Compression was OK but repair guy heard a knocking. Diagnosed a crankshaft problem. After removing crank, he told me both lower needle bearings were shot - probably caused by all the cranking to remove the water with nothing to lube the bearings because they were sitting in water.
Is this really the cause? When should I have stopped cranking?
Thanks!
Thanks!
