jpugatlanta
Just about to reassemble my 2000 787 rfi motor. When i split the cases, which were stock. I don't see any traces of any sealant from the original assembly. Maybe a bit that looks like it may have squeezed into the bolt holes (red in color) but was that from the bolt? I plan to use a sealant, but is there actually a sealant from the factory?
Could i used Permatex 80062 high tack gasket sealant? When i used this on older vintage carbs o-rings where it was an issue finding a replacement o-ring, (and having fuel leak reusing o-ring) it worked perfect.
