PalmBeachSeadooer
Hello everyone. I recently purchased a '98 GTX Limited. Love the machine, its runs FAST! At least for the first few times I had it out! Now I have all kinds of fuel issues, poor performance, idling issues, and from doing my research here I have decided to do several things and get my ski back up to par:
1) new plugs - done
2) clean RAVE valves - in process
3) new bilge pump - in process
4) replace all the old gray fuel lines
5) new fuel filter, clean out fuel selector valve, new fuel pick up filter
6) clean out carbs
7) dump old fuel
One thing I have a question about is should I convert this system to an oil and gas mixture instead of relying on the oil pump system? I live in South Florida and have discussed this with several dealers in the area and ALL the shops guys, to a man, say to bypass the original oil pump system and go to mixing the oil in the gas. They say the pump and/or the line that feeds the oil to the motor will at some point fail and fry my motor. Any thoughts on this? Or is there a thread on this forum that discusses this? I have not been able to find it if there is.
Thank you in advance for your info and opinions. I have already learned A LOT from this forum!!
1) new plugs - done
6) clean out carbs
7) dump old fuel
