check to see if it is the cable that is tight, once the cables get worn they start to bind, and eventually break. if you disconnect the cable from the shifter and the shifter moves freely and you disconnect the cable at the reverse bucket at the back and the bucket moves freely then you will know that the cable is the culprit, with everything disconnected the cable may not feel like it is the problem because there is no load on it where it is worn.
