I have a seadoo gsx 800 1997, its been running well and have had no real problems (since carbs rebuild). I borrowed a compression tester off of a friend just to see what compression the cylinders were, they are both about 75 psi, from reading on here i see it should be around 140. its done 100hrs and is running fine, does nearly 60mph, accelerates good and starts up fine (and tows inflatables) my question is should i investigate the low compression or carry on as i am, thanks
