Clutch flywheel
zoubert
HELP HELP !!!! We would like to know how to catch off the clutch flywheel of the shaft on Rotax 787 1996. THANKS A LOT THANK YOU VERY MUCH :
Excuse me for my bad english
either your referring to the nut, which you'll need an impact, and/or referring to the flywheel itself, which then, the flywheel removal tool, is what yuo'll need.
If the motor is still inside you should make a metal brace screwed to the rear mount to prevent tearing away the rubber motor mounting blocks, if the motor is out all of this is easier because you can acrually see what you are doing, it is always very tight.
