CLICK/DOINK SOUND COMING FROM CDI RELAY IN FRONT GRAY E-BOX WHEN START BUTTON PRESSED
Narrowing no start problem to the front of the ski. When I press start button, nothing happens EXCEPT. CLICK/DOINK sound coming from holder relay in front gray e-box. Should I just find another relay (hard to find) & swap, or does anybody have any ideas what else i should check for before going ahead and changing CDI (holder) relay
The holder relay gives 12V power to the CDI. Ihf you just press the start button with no key it will click and give 12V to the CDI for about 30 seconds. If you go to normally start the ski the holder will continue to supply 12V to the CDI while cranking. If the 12V disappears then the relay might need replacement. You could test for those conditions with a voltmeter and schematic. You could also jumper across the holder relay so that it always supplies 12V to the CDI temporarily to see if the ski then starts normally. If it does then replace the relay. Don't leave the relay shorted while the ski is not running because you will eventually drain the battery.
Thanks for your input artr. I need to research how to do the tests you mentioned, however, one other piece of info I left out above is this: When pressing starter button, nothing happens and there is no click/doink coming from grey box BUT when I disconnect start button and trip the plug that the start button goes into with a wire, THATS when I hear click/doink. Does that mean potentially BOTH relay holder and start button are bad?
Test start button with an ohmmeter when disconnected, should short the connections just like you did.
artr, I like your idea to jump across relay to see if it needs replacement, however, what 2 out of the 4 wires do I cross? Do I also need to do this with the start/stop switch wires crossed ? (I checked start switch and showed no continuity with the button both pressed and not pressed. I will order new start switch. ALSO, yesterday when crossing start switch wires I got a click/doink all within 1-2 seconds of each other. Today when performing same procedure I got a click...then 30 seconds later, a doink. Should I assume this means the holder relay is good?
You short the red-blue stripe to the red-purple stripe and then short the start button connection like you did before. The key should be on the post. If it starts and stays running it's probably the holder relay. Does your beeper work? Do you get 2 beeps when the key is placed on the post?
Thank you for this clarification artr. I will keep this in mind but won't do anything yet because after fiddling around with the connections on the holder I noticed they weren't too difficult to take off so I re-attached them and Low & Behold, it cranked over several times in a row. I'm not sure if it was a fluke or if that REALLY solved the problem. However, when I did start it, it appeared to be getting full power out of only 1 plug. This happened last year so I cut spark-plug wire 1/2 inch & that solved the problem, but when I tried it again yesterday it made no difference even when swapping spark plugs. I'm wondering if I have a bad spark cap. If I do, do you know if I can just go to auto parts store & pick up one that will work or do I need to get a special Seadoo one. I know this is unrelated & probably requires a new post, however since I already have your attention I thought I'd just put it out there.
I don't think there's much to go wrong with the spark plug cap. You can try swapping the 2 Caps And see if the problem moves with the cap. I also know there's a certain resistance measurement in the shop manual for the entire spark plug wire including the cap. I think the caps are marked NKG.
You should probably clean the connectors to the holder relay and make sure they are tight.
First time posting in the forum but I've been reading these for years and there's a lot of great information here for anybody new coming on and I thank you personally.
Bypass the stator on startup if this happens, clunk clunk click click. Dreaded sounds but I had to post for you all because this bypass is quite frankly it was most incredible find for the older jet skis, and quite frankly I have a lot I've had a lot and have worked on thousands more, because I don't know how many starters and starter relays I've swapped out. When I was testing every single circuit I put tester negative to negative start stop and the positive on the positive battery and I showed continuity right across the board as well as 12 volt obviously but it was going through the engine the MPEM which essentially showed a short circuit in the mpem and technically it is but you can bypass it and make it work in your favor it's not really a bypass it's a switch out just to cut it out of the circuit for a second. I actually ran the bike for like 5 minutes without it on it's okay still and my battery charge back up to like 13.2 Disconnect the four pin plug on the alternator and you should lose continuity as well as the power supply. Yellow wire will be good when you test them out
it's the black black red telltale.
The plucking sound coming from the start stop relay engaging the solenoid or the starter are the worst. Testing out the stator I found it good. The black and black red wire was over 20 ohms. It was leaking causing my power drop
Bypassed in about 20 minutes
two switches four long wires; I did number 14 wire and soldered connections and just heat heat shrunk over them before the connection on the stator or MAG side plug, routed forward, easily accessible you can mount and you can functionally access so that after the bike starts up like a charm it'll be black and white truly and these will be mounted in the normally open position whenever you stop you should just swap them over you'll probably notice any kind of parasitic draining and your battery will always be top notch and after taking off I engage them to a closed position to start charging the battery again there is no feeling you can't even tell the difference and found it even when clicking one on at a time it didn't cause any stifle and the draw is the same as what it was before it was happening just now I can start my bike so much easier. It's like the whole way to the engine just lifted off of the battery and now all has to do is fire up the starter and throw a little spark your spark cannot go anywhere except to the CDI now it's straight to the spark plugs.
In short to recap,
cut the two yellow wires engage or disengage your alternator two switches in across the yellow wires disable the wires for the AC that comes from the alternator. Now you have no voltage drop start your bike, your starter will sound like brand new. After starting, lip switches to the closed position or on you'll start charging again. A little cumbersome with the extra switches but I didn't have to pull that damn stator out. Work like a charm runs like a dream this could save a lot of headaches.
I picked up a couple of stx's 1100 recently I think I'm just going to add the switches in the circuit just to help it start better I'll keep you posted. And thanks again for everybody else in there contributions in the prior years saved a lot of bacon.
Best regards
