Aaronl522
Hello all I'm new here, I'm automotive inclined but newbie with boats.
I have a 1999 sea-doo challenger jet boat with a single rotax (787?) That will not crank/no spark at plugs.
When putting the lanyard on the post, the dash gauges respond and light up but I cannot get a single Beep. (I ordered new beeper today). When testing the positive side of starter relay I've got 12+volts but on line going to starter remains 0 volts that supply the starter power no matter the start button being pressed or not.
1. I installed a new relay thinking that was bad. Still same problem.
2. Installed new neutral safety switch . Still same problem.
3. Checked all fuses (none blown) and replaced all with new fuses just because.
4. Checked all wiring from dash back to rear fuse panel (MPEM) nothing exposed. With lanyard attached and battery switch turned on, i checked voltage to each fuse on mpem and each receiving 12+volts. Fan works, radio works, bilge etc
When pressing start button you just hear one single click coming from rear panel under the hood/hatch and rpms drop from starting position to zero on the dial. Then after about 30 seconds you hear another click from the automatically like the boats (reset) once this happens you can press the start button again and get the same "one click" issue. Pressing the start button more then once wont make it click more it only makes 1 click that first time. Battery is good. Plugs, wires new. I sanded down and tightened the grounds for battery, gauges everything I could reach. Fyi the 10AMP fuse under the dash in front of steering wheel had a popped fuse when I bought boat. I replaced it and nothing happened.
Is the MPEM bad? I get no beeps .
I've tested the yellow wire going into the relay that comes out of the mpem and it has no voltage at all at any point with or without key.
Pressing the start button 5 times I get like a squeal 1 short and one long squeal assuming the beeper on it's way out. What's this mean? Any help is appreciated thank you in advance.
Does not have twin rotax engines just the single rotax
