Hi everyone. I have a 2014 Sea-Doo Spark 3-Up 90 that has about 40 hours on it. I only use it in my local lake and have never had any issues with it until my last trip out. Everything was going fine and then the next time I started it I got the long beep and the check engine warning. I shut it off and looked in the engine compartment and couldn't see anything out of the ordinary. I filled the tank with 91 octane and put in a few ounces of Heet in case it was water in the fuel. I started it back up and got the same thing so I decided to drive it a bit. Above about 10 mph when I'm accelerating, the check engine light goes away and the ski runs perfect. Same top speed as always and engine sounds like it is running fine. When I slow down, if I get below about 15 mph the check engine light comes on with the long beep and the engine seems almost like its chugging a little, not the same smooth sound it usually has Also, when I first start it, it runs fine for about 5-10 seconds before I get the beep and warning light and before the engine starts chugging but as soon as I get above about 10 mph, like I said, it runs perfect and the light goes away. Any thoughts on what might be causing this? Thanks in advance for any help.
