snikwad003
1. Where did the pcv vent to in the gtx?
2. Could you be forcing air into the motor somewhere with the s/c?
3. Could you put a barb and a cheap tiny airfilter on that block off plate like you get for the valve cover of a v8?
4. Could you could add a catch can if it is oil regurgitation?
5. Is there a backwards check valve some where in the system letting boost into the crankcase and not letting it out?
6. how about some nitrous?
7. Is your head gasket sealed up right?
8. Massive ammounts of blow-by from new rings (did you get new rings and pistons?)?
9. Does your VW tow rig roll coal towing yer boat?
		 no way I would ever have enough room with the fuel tank being right there.
