ODavis
When you remove the engine from a single engine Challenger 180 does the engine still have to be re-aligned, if you remove the top single bolt from the engine mount and not the entire mount? I am about to remove the 4-Tec SCIC engine and just starting to do some research on the specialty tools needed. Seems there is a long costly list to accomplish this.
The washers exploded on the SC and I am going to clean out the engine. Although might go with a long block because I also want to change the valves out. Thoughts?
