Linwoodinmaine
Just looking for some advice wondering if anybody has run into this had a hard time getting the jet assembly off because someone had used a black rubber sealant and pretty much glued the unit to the Hull after I did get it off as seen in the photos below I believe I will have to replace the wear ring because the plastic piece that sets against the seal is gone. I also didn't know what seals the bladder lines that go in the top above the jet unit is there a gasket or something that goes in there?
