Greetings All!
Any help here is greatly appreciated. Recently, while my 2007 Seadoo GTX was idle in the water, the hull of the seadoo filled with water. I brought the machine ashore, filled water just above the shaft and seen water leaking from underneath the Seadoo. Pretty much tells me that is is a cabon ring issue (fell free to correct that assumption).
So, I am going to replace the carbon ring and looking for assistamce in this process (i have done lots of research before posting but could not find a clear process for replacing a carbon ring on an 07 GTX 4Tec). The research i have done says i have to remove the pump, etc and then remove the drive shaft to get at the carbon ring. Some posts state that i must have a special tool for the shaft? is this correct? what is that tool and is it vital to this process? If I am replcing the carbon ring, what else would need replacement?
Again, any assistance is greatly appreciated.
Cheers!
Phil
Cheers!
Phil
