carb adjustment?
mcclelland32
I got a 99' gtx limited and it was tuned to run at 5000+ elevation. Im in San diego and we are at sea level. Can someone tell me what i need to adjust on the carbs and how? Thanks in advance.
Carb Adjustment
I think I would just leave the carbs. alone. I looked in the manual and saw nothing about adjusting the carbs for higher elevations.
Theoretically you could go leaner at a lower elevation but you also run the risk of running too hot. Like Harry Truman said "if it ain't broke don't fix it".
Lou
If it was set up to ride in that elevation I would check the carbs to see if they made any changes from stock. More than likely they just replaced the impeller to something less steep.
