Shop Discount Sea-Doo Parts
Cannot get jet pump off....
spx787
Messages
359
Location
SATX
Water Crafts
97 SPX800
96 GTX
I got my new wear ring and driveline rebuild kit today. I wanted to install the new stuff this evening, however, I cannot get that jet pump off to save my freakin' life!!!!
I took the nozzle off and then took the four nuts off that hold pump on. I can see some silicon on there but it feels like more than just silicon is holding it on there.
I was gonna take the skid plate off so I could get a flathead in there and try to pry the pump loose. I took the screws out of the plate and can't get that damn thing off either. I do not want to break or damage anything so I didn't try manhandling anything.
Any suggestions? How does that skid plate come off? I think if I could get that off then the pump would pry loose.
Ski is a 97 SPX.
WhiskeyD
Messages
886
Location
Charlotte, NC
Water Crafts
96 XP & 97 SPX
I loop rope through the pump and attach it to a come-along. Make sure you disconnect the cooling and bailer lines on the inside of the hull first. They can take a lot of force to remove sometimes.
racerxxx
Moderator
Moderator
Messages
10,805
Location
Chalfont, Pennsylvania
Water Crafts
89 SP, 91 XP,(2) 96 XP's, 99 Speedster Twin 800's , 95 HX, 95 XP800, 98 SPX
Yep, gotta remove the lines inside.
racerxxx
Moderator
Moderator
Messages
10,805
Location
Water Crafts
Behind the vts box and exhaust hose.
racerxxx
Moderator
Moderator
Messages
10,805
Location
Water Crafts
The fat water supply line is clamped on the 2 bailer lines are cable tied on.
Luv2Camp
Messages
558
Location
Ohio
Water Crafts
1995 GTX,
2012 Bayliner 185 4.3l
Even after you get the lines off, may still be stuck on there. Will even seem like you missed a bolt! I usea "morgan knocker" ( a large dent puller tool) that has a chain attachment. It can take some time and force to get it off. I would caution against prying it as you can damage the pump and or the hull...
spx787
Messages
359
Location
SATX
Water Crafts
97 SPX800
96 GTX
I haven't gone back to look at it since all the advice given here but I am curious, what the hell is holding that thing on? Like I said, it looks like somebody used silicon on it, but the grip it has seems like more than that. Is it the driveshaft splined into the the impeller?? Also, I will probably end up hooking the trailer up to my blazer because I was pulling the trailer backwards when trying to yank that pump off by hand.
I guess I need to go purchase a come along this evening. Not sure what I am going to attach the hook side that's not on the pump to though.
It's always the jobs that seem they will be simple that kick your ass.
CReynoldsMIZ
Messages
2,681
Location
midwest
Water Crafts
none
one time on a 96 xp that i had, the splines were stuck into the pump, and into the splines in the pto. a few pumps of grease into the pto pushed them out and it popped right off. long shot but could be
nckb
Messages
186
Location
south east nc
Water Crafts
96 GTI
96 GTS
I too fought the nozzles on mine earlier this summer. The GTS (metal nozzle) was really stuck. I got it off by using a hammer along with a short piece of scrap 2x4 to knock it side to side and break the silicone loose. I'm not sure if this is a recommended practice, but the wood block with hammer is my go to method for anything that is stuck, and is harder than wood. I go through a lot of wood blocks.
Spimothy Leary
Messages
7,702
Location
SW Florida
Water Crafts
2008 RXTX
laff @ the last sentence...
but seriously, I've used a piece of 2x4 several times to get a stubborn pump off,, usually just had to wedge it in there and wiggle/bang it against the side of the hull a couple of times to get it to pop, then pull if off by hand from there.
spx787
Messages
359
Location
SATX
Water Crafts
97 SPX800
96 GTX
My housing is the plastic one though. The last thing I want to do is crack that housing.
96spxpos
Messages
2,030
Location
Anna Maria Island, FL
Water Crafts
1995 Seadoo HX
1996 Seadoo SPX
1988 Mako 18.5ft Center Console
Yea, the first time I went to go take mine off, I was at my wits end too..until I cleared my head, applied logic, looked into the hull, and noticed that I had to remove the pump lines from inside...I can almost GUARANTEE that's your issue..if you're asking how they're held on, you obviously haven't disconnected them...After that, you'll literally have to just give it a few taps, if at all..
- BiRkS_
Messages
883
Location
Mississauga, Ontario
Water Crafts
'91 GT 587
'97 gsx 787
'98 xp 951 ltd
2000 GTX M/E 951 (sold)
75W90 synthetic gear oil seems to be the choice of oil.
As to getting the pump off, i have a nice easy way. get a small length of chain. attach it to where the pump nozzle mounts using 2 of the bolts (diagonally) and run it in snug them up. you want a fairly small loop of chain. Then sneak a 2x2 piece of wood through the loop and pry away from the hull. Pulls them off like butter. So simple, no special tools, just 2 bolts that you already had to remove.
spx787
Messages
359
Location
SATX
Water Crafts
97 SPX800
96 GTX
Well after much strife, I finally got the pump off. Wear ring is fooked! Unfortunately, I somehow broke off the damn water supply nipple. FML! Is there a repair for this or do I have to buy a new pump housing now???
Mekanix
Messages
2,024
Location
Halifax, Nova Scotia, Canada
Water Crafts
96 GSX 800 :D
2000 GS 717
02 gtx 4 tech :s
98 XPL :/
99 XPL :p
2001 XPL :)
2000 RX
2002 RX :)
lol You worry too much
Those are about 3 bucks and they screw in and out.
So just find something like and easy out or maybe just a bit flat screw driver and try and unscrew the piece that is still in the threads.
But good job getting that thing out :)
spx787
Messages
359
Location
SATX
Water Crafts
97 SPX800
96 GTX
What is that nipple called? I'm guessing SBT will have em? And yea that pump was a pain in my balls. Used a chain, a ratchet strap, a 2x4 and a hammer. Sheeeeesh!!!!
Mekanix
Messages
2,024
Location
Water Crafts
96 GSX 800 :D
2000 GS 717
02 gtx 4 tech :s
98 XPL :/
99 XPL :p
2001 XPL :)
2000 RX
2002 RX :)
Trying to find the part number. Its a really common part. like the bailer ones are 2$ a piece usually. That one can't be much more.
Mekanix
Messages
2,024
Location
Water Crafts
96 GSX 800 :D
2000 GS 717
02 gtx 4 tech :s
98 XPL :/
99 XPL :p
2001 XPL :)
2000 RX
2002 RX :)
293-700-019 and its called a pump fitting.
And the ones for the bailer's are
293-700-017
spx787
Messages
359
Location
SATX
Water Crafts
97 SPX800
96 GTX
Thanks man! Sucks I can't take the ski out this weekend because I'll be waiting for the part. That's not something I want to jerry rig though. If it happens to break off again while I'm riding, my engine is screwed.
spx787
Messages
359
Location
SATX
Water Crafts
97 SPX800
96 GTX
This is what my wear ring looks like.
I've only owned the ski for about 3 months so it's safe to say I've never felt the thing at its full potential with that wear ring lol!
SPONSORED LINKS
Latest posts
Usergroup
