I looked at the supercharger removal video for the RXT. Then I read that the
Process is easier with the 2006 gtx limited. If anyone can take me through the
Process or send an updated video I would very much appreciate it
Is pretty easy. Remove the rubber pipe connecting it to the intake, and remove the the bolts that hold it. Next, gently pull it out of the block. You may have to remove other things like the coolant bracket or whatever is in your way.
- Remove the cross piece under the seat.
- Remove the S/C intake and exit hoses.
- Remove the band clamp between the exhaust manifold and J pipe.
- Disconnect the two small cooling hoses between the exhaust manifold and J pipe.
- Slide the water box and J pipe rearward about 3" to 4".
- Remove the three bolts holding the S/C to the block then slide it rearward and out.
The first few minutes of this video show the S/C removal.
I have done quite a few SC rebuilds for local guys and have not had a problem, yet ! I'm sure my time will come eventually. For the top bolt a 1/4" twelve point wrench works better than the oem tool.
Just removed mine - 2013 GTR215. In mine you have to move a bunch of stuff. Tip...the top hose connected to the engine block IS filled with pressurized coolant. Took a whole roll of paper towels to soak up coolant. It was convenient when it was moved though. Why TF did SeaDoo put that one in the back. That just sucked. Supercharger on it's way to Tampa.
