mkov608
Are cam sensors a problem with 4-Tec engines? Are they known for intermittent faults?
I picked up a P-0344 fault last week. The ski ran great even with the fault. I pulled out the manual, and my Power Probe 3. I have 12 VDC to pin 3 of the sensor, and I had continuity between pins 1 & 2 to their connections at the ECU harness (20 & 34). I didn't have a 1200 ohm resistor handy, so I couldn't perform the voltage check on the sensor.
I cleared the fault with my CanDoo, and ran the ski on the hose. So far, the fault hasn't returned.
Thanks in advance!
Mark
Thanks in advance!
Mark
