Willy.Fire
Hi I have been searching for a pwc for well over a month now and Im pretty much set on buying a 98 and 99 GTX limited pair on trailer. These will be for our family to use (3 kids) and will be our 1st sea-doos. Anyways I thought I would check with some experts here on what to look for when I go look and possibly buy. Here are some details.
Previous owner owned for 9 years and is a mechanic he said they have not seen water for 3 years and over the course of 9 years only around 10 times. He has started them every spring and winter and said has winterized every year. Always stored inside this year when starting he found 1 to have bad solenoid and starter so this needs replaced. the other one runs fine. Hours are 150ish and 160ish 2 new batteries this june and compression in june on both were 140ish. Exterior is in good shape just dusty from sitting in garage. Price is really good but I wont be able to do a water test unfortunately so this scares me. I will do compression test is there anything else I need to worry about? Should I stay clear of them since they have sat so long with out being on the water? Im scared when i get them out I will find more things wrong? Thanks for any input and if I end up with them im sure I will be here for help on what I need to do to make these as reliable as I can for our family to use.
