bone head mistake
dirtdiver
Well over excited today, listen to forum fixed the problems and the trailer i go except i forgot to put the plugs in? Never made it off the boat ramp. Finally got the ski to start took hours, since i got it to run again did i mess anything up. I did not try it in the water didnt seem to sound very healthy. The plugs were toast. I will put new plugs in the morning.
Please help
David (water downed)
If you got the engine running, and went for a ride... then no... you shouldn't have hurt anything.
dr honda it ran later but ran out of daylight the water didnt get over the carbs but i did take some in though.
Thanks again
david
U need to run the motor to burn the moisture out or it will cause internal engine problems fast get it running and run it as long as u can
U need to run the motor to burn the moisture out or it will cause internal engine problems fast get it running and run it as soon as u can
Well it ran great when i put new plugs in it today. My son wouldnt let me ride it i rode the waverunner, and had a hard time chasing him. But i had another issue i had turned the low idle screws out another quarter turn ski wouldnt start gas came out the spark plug etc. Once i turned in the qtr turn and let everything dry bingo. Again thanks for all the help.
David
