karfreak09
Hello,
I am fairly new here, although I've done my fair share of reading some of the great info on here. Thank you for that.
I purchased a 1994 speedster a month or so ago, and I've worked out a variety of kinks so far (fuel gauge, seats reupholstered and so on).
Problem 1: The boat seems to smoke quite a bit, i know some is normal, but how much is too much? The boat puts out a heap of blue smoke at startup, and still a pretty good amount when cruising slowly around 2500-300 rpm. It seems to go away after that, but it could be the wind blowing it away since I'm moving quickly. The compression is decent on every cylinder, 143-148. The engines seem to start and run well and produce enough power to get up on plane an drive around 43 mph max (gps). Is the boat supposed to be able to go faster than this with 2 people in it? I would appreciate some advice on what could be making it smoke so much, oil pump adjustment, or some seals...
Problem 2: The boat takes on water in the engine/bildge area when driving, and only when driving/engines on. I can sit still in water with the engines off and no water will come in. I am thinking that this has to do with some seals being deteriorated and leaking but only when the jet pumps are pressurized. I would appreciate any advice, including jet pump rebuild, which i am considering.
Thanks for your time.
