Best Battery Brand
Smithlake
I have a 97 GTX and 95 GTS. I have had poor results with batteries lasting only a year or two. Is this normal ? Should I pull the battery and store inside during the winter ? Does anyone leave a trickle charger on their battey ? I have used the dry cell type odyssey battery and lead acid type. Does anyone have a brand that performs better than another ?
couple years?........
A couple years for a battery is about the norm........I'm sure there are some out there who pay for that high dollar battery and it last a little longer. I just buy from Advanced Auto supply, for less than $50 bucks, it gets me through the season, then I buy again the following spring.
If you keep it through the winter months, then yes, you should keep it from freezing temps.
I use a 2 amp trickle charger, but not daily. You'd need a "tender" for that.:cheers:
Deka brand batteries are what I use... My 03 GTI LE RFI still has the origianl battery in it, and my GTX would have if the battery caps hadn't broke...
If you pull the batterry and check fluid level, and charge once a month to 13.4V they'll last...
