Going to check oil pressure with a gauge tonight. May be going into limp mode from low oil pressure. No codes from my CandooPro software. I have replaced the oil pressure switch last fall. It wasn't it. The gauge cluster doesn't work. I replaced with gauges. Fuel, RPM, GPS, with individual gauges. It ran fine before this without gauges hooked up.
The long beep is a communication error with the cluster. If you're not getting a code, it's not going into limp mode. The cluster is an important part of the system on 2006 and newer. Are you leaving the cluster plugged in?
My cluster is bad so I replaced with gauges. Fuel, RPM, and GPS for speed. When I bought this Seadoo last year, lowest price cluster was $750. Now they are $420 on ebay. $420 is expensive, but better than $720.
My neighbor just bought a 2007 RXT with a bad cluster. I asked him just this evening, if his jetski ran with the cluster completely unplugged. He said it ran just fine with all connectors unplugged. He is waiting for his $420 replacement.
