Bearing/Seal part numbers for MOVE 1 Karavan trailer
TonyZLR
Hello,
I have a 2012 Karavan MOVE 1 trailer that came with my 2012 GTI130 PWC. I need to replace the bearings and seals
in the hubs, but can't seem to find the correct part numbers online. Is a parts drawing available somewhere online
that specifies the part numbers for bearings and seals? Or maybe someone has changed these parts and can tell me
what they used and where they purchased them.
Thank you.
Tony
All bearings and seals will have a number on them that should cross reference.
You will have to pull them though.
Yes, I know that. But I pulled one hub off, and could not make out the numbers on the seal or bearing. They were only partially stamped in the metal, making the full numbers unreadable. :(
A bearing supply shop should be able to match things up if you can get the parts to them. Not sure what you have near for a shop. Even if they can't read all the numbers having the parts there for them to measure should be enough to get you what you need.
