eavega
So in the process of getting my '95 SPX running, I went with a less expensive lead-acid battery until I was sure that everything was in good running order. I figure I'll move to an AGM when the flooded cell I bought inevitably dies. In the meantime, I make it a habit to keep the batteries on my various devices (generator, boat, motorcycles, etc) on trickle chargers so they are always topped off. I've read warnings against doing this on PWCs as the trickle chargers can damage electric components. Keeping the battery out of the ski is not my preferred option (although that's how I have it now during the winter). To make matters a little more complicated, Where I keep the ski there is no easy access to power. This leads to several questions:
1. For my boat, I keep the battery topped off with one of these http://www.northerntool.com/shop/tools/product_200655383_200655383
Would this work for the PWC battery completely wired up in my PWC? The specification is that it has a max output of 2.5 Watts, but I have measured the voltage as high as 15V when in direct sunlight. I didn't know if there was a risk of blowing something out.
2. Would putting an inline switch or battery isolator be advisable or recommended? That way, I could isolate the electronics while I am charging the battery.
3. Am I overthinking this and I won't damage anything using either the 2.5 watt solar panel or a plug-into-the-wall battery tender?
Thanks in advance for any suggestions you all can offer
-Eric
-Eric
