RiverRat928
( SORRY for long post, thanks for thoughts and opinions)
I recently bought a 97 speedster. I have run it about 7 hours since I purchased it. I had it out a week ago and finally got to see what it was capable of ( took it out by myself, without the wife and daughter ). I did a few high speed turns and spins ( WOW so much Fun !) and hit a few big boat wakes ( hard landing... ). I got back after dark and put boat in garage without inspecting the engine compartment. I then left for a week of work out of town. I returned today and found that the battery tie down had come loose (possibly broken), and the battery was laying on its side. It leaked battery acid all over the fiberglass and stained it rust color. I pulled the battery and put baking soda all over the spill, and rinsed out the inside of the hull really well. The fiberglass is stained but doesn't feel soft or flaky.
Has anyone else experienced this?
Is there anything else I should do to clean or seal the fiberglass ? Should I be concerned about long term damage? ( weakend glass )
Has anyone come up with a better way to tie down battery ?
The battery was only a year old and WAS in good shape, two cells are dry and the other 4 are three quarters full, can I salvage the battery by filling with distilled water? or should I plan to replace (maybe AGM to avoid this again)
I also found that the starboard side motor is loose, I found this by tugging on the exhaust pipe ( a suggestion I found on this forum..... thanks). I know it was not loose prior to the last run. The base plate mounted to the rubber isolators is still intact on all four corners. It looks like engine is loose from base plate, how do I fix this ?
