twentythreemx
Alright I'll try to keep this short... recently bought a 96 hx and 95 XP. Both ran iffy. Changed out all fuel lines and cleaned carbs. XP is doing great. HX.. well tonight...i dont know.
Yesterday I had it out, plugs looked a little lean. Checked the oil cable adjusment, the alignment marks were a little off, on the LEAN side. So I put it where it should be, spot on. Rode it for about an hour and a half tonight, and it came to an abrupt stop. Tried to start, click click, wont turn over. Get towed back in. Pull the plugs. Both look lean. One looked very lean, the other not AS bad. The rear (pto?) plug was the worst, mag (front?) not as bad. Pic to follow.
I instantly thought top end, and that maybe the oil cable didnt get tightened and it came out of adjustment. Pulled airbox off, got my mirror out.. right where it was. Pulled plugs, tried to crank again... it turned over a little but very slow. Figured I'd pull the head off real quick. Cylinders look OK. It will turn over but it struggles.
What do I do? I have 2 concerns obviously... 1. What is wrong.. and 2. What caused it. Hate to fix it and have it happen again.
Could something be stuck or jammed somewhere? Could it be something w/ the drive shaft? Did it starve for oil? Crank bearings? sucking air (dont think thats it) I don't know where to start or what to do. I've done a little work on these things but not enough apparently. Anyone that can start me in the right direction, I would appreciate it. Or if anyone wants to come buy a nice non running HX, come get it. lol.
Looking back, I should have stopped and checked the plugs, but I figured it was richer than before and running decent.. to late now. Also... not sure what oil is in it. It was half full when I bought it. Was going to finish it through, rather than draining it and refilling, before switching over to xps. who knows what was in there. hopefully that didnt have anything to do with it.
Here's the plugs..
Here's the plugs..
