kernal
Upgraded to JL Audio components. MX770 speakers and a MX 500/4 amp.
Sound is much improved over the stock Jensen setup, but there is a low hum from a ground loop issue. This has me re-thinking how I connected the amp. I ran a dedicated power / ground from my #2 battery. I think I need to move the head unit ground to the amp ground, or install ground loop isolators on the RCA's.
I'm also now thinking that I should have ran the amp power from the battery switch, instead of straight from the battery #2. That way it would draw from the "active" battery. IE now if I select battery 1, the head unit gets power from it, and the amp is drawing from batt #2.
Any recommendations?
