tom scheidecker
We bought two low hour RXT's last year and the SC was not working on mine. We hadn't looked at the forum and didn't know much about these boats. So now I'm tearing into the oil pumps, got the front one off and found about half a washer in all sized pieces, and damage to the pump. I need tools to get the driveshaft out so I can remove the PTO cover to get to the back pump, but I'm expecting the same.
So, to anyone who has done this before; What are the chances the oil pumps ground the pieces fine enough to go through the whole oiling system?
Seadoo says the pump parts must be changed and there is wear in the cover and the housing of the front. Will I tear up new pumps with grit that might be in the engine, or is it better to tear the motor down?
I have seen two part numbers for the separator tool for the driveshaft. 529-035-841 and 529-035-987, the last one, I read somewhere, was for supercharged engines. I've seen four or five tools for driveshaft removal. Do I need them all?
I thought I would find grit in the oil passage holes behind the pump but I didn't find any pieces there. Any help would be much appreciated. Thanks Tom
