I have a 1999 GTX RFI and sounds like the starter is going (my guess). When I start it on the trailer the starter is intermittent (usually starts after 2-3 pushes), it starts to engage then the bendix disengages from the flywheel. If you hit the button as soon as the bendix disengages the starter just free spins. Now when I put it into the water it'll start once or twice then after that the starter keeps doing the intermittent/disengaging routine. When I first got it (2 months ago)  it only did this once in a while, now it does it every time I start it. Battery is new and I keep it on a battery tender, charging system is good 13.3-13.6 volts running. The start solenoid is new and all the battery terminals are clean. I jumped the two battery posts on the start solenoid and it does the same thing. I think it's the brushes or clutch, any input would be appreciated.
Thanks
Ted
			Thanks
Ted
