the boat has twin engines.
Port works great it will hit 7000 rpms no problem. The starboard engine will not get above 5000 rpms unless I jack the throttle several times.
The marina said it was the stator and replaced it.....same problem
Then they said the engine needed replacement and replaced the engine...same problem.....yah I no longer go to them now.
I took it someone who works on jet skis and boats and he looked at the old stator (i still have it) and he said it was perfectly fine. he also tried to solve the problem and after exhaustive diving into the engine compartment he thinks its the electronic module. The problem is if I buy the module and that does not solve the problem there goes another $1400 not to mention it is not made any more which makes it hard to find.
Any suggestions would be so very much appreciated.
