micro222
This was quite a head-scratcher for me, but I eventually figured it out. I’m posting this in case someone else runs into the same problem.
The engine would run perfectly until a specific RPM was reached, then it would suddenly quit. I could restart it immediately and resume, but it always happened at the same RPM.
I disconnected the wire from the MPEM to the ignition module and no more problem.
I couldn’t leave the wire disconnected because then the lanyard or stop button wouldn’t shut down the engine. To fix this, I installed a relay between the lanyard/stop wire and the ignition module. It now works perfectly.
