wolfie
this is for all the di fans rebuilt top end of engine do to low compression over the winter. took the (2000 gtx) out on the water today to break it in and see what I had. she starts up fine and idles good. took throttle on the trailer in the water good. went for a ride and it would not give me over 3500 rpm. ran it for about 10 minutes and brought it back to the trailer and home. It never just died on me at all. Took a compression test both sides were at 145 psi. what I didn't like was my brand new spark plugs were black and dry. I don't think it is my injectors could there be low fuel pressure and I need to pressure check? I had taken the fuel pump out and changed both fuel filters over the winter and they were not to bad. I have good fuel and oil. will they run and idle with a fuel pump that has a little low fuel pressure? Any help and direction would be great. thanks in advance
