Ok I have read numerous threads about starting issues last year I had trouble sometimes starting the ski in the water this year I cannot get it to turn over. I thought I had it narrowed down to the solenoid so I bought another one because it would have been an easy fix. I have also cleaned the ground going to the block so I don’t think that’s it. I have a good 12 volts on the battery side of the solenoid with a good charge to the battery when I hit the starter I get roughly 3-4 volts on the starter side of the solenoid while I have a good 12 on the other side. My volt meter negative is going straight to the battery and is still getting the low voltage.
I checked the continuity of the solenoid and it is good so I am stumped any ideas on what would cause the voltage drop? I have checked all fuses and connections. I pulled the plugs and the starter would sometimes spin the motor but not always. I have yet to pull the starter and play with it because it seems like it will be super hard to get out. But I suppose that will be my next step unless anyone has any ideas.
Thanks in advance
Thanks in advance
