Hey Matt, I find it interesting that your PTO was hotter than your MAG cylinder. I've been trying to hut down the cause of my PTO running 100degF cooler than my MAG cylinder. Some guy on PWC Today said that it's because the MAG has to make such a tight turn relative to the PTO at the Y-pipe. I'm having trouble believing him, as I can't see SeaDoo designing a 2-cyl engine with such a drastic temperature differential. I've been through the carbs, and despite having adjusted the Pop-off to be the same, I saw no other differences. That made no difference. I took out the plugs yesterday and saw that the insulators are both nice and chocolate brown. I guess that's a good sign, though I would really like to get my cylinders to the same temps. It seems that even when I screw the High needle all the way in, it barely makes a difference on the EGT temp on that cylinder. I heard that if it's knocking, it will get cooler (but in a bad way). How can you tell when a Rotax pre-detonates?
Normally it is the rear cylinder that has a problem burning pistons when one starts bolting aftermarket pipes on. You should be OK if those chocolate brown plugs came directly after a long wide open run. Knocking from pre-detonation in these engines means that the top of the piston has bad news waiting for you. It can be caused by low fuel octane(old gas), improper ignition timing settings, incorrect spark plug, lean fuel mixture, etc. You must back off the throttle at the very first "ping" that you here. It is normal for the high speed jet to be closed on these carbs. I like "lightly closed".
I bought a real Coffman's pipe today online(race version with a water jacket) and got a call from that welding shop saying that they fixed my Neptune pipe. I'm very excited about both. I'm bringing my Mikuni carb pop off tester to make sure the Neptune hold pressure. If it does then it's going on this weekend!
