none of this is nonsense.
Frank: Here's the deal.
some people buy a "performance enhancer" and expect a certain level of change for the $$$$. The problem is... in a boat/PWC... it takes a HUGE change to make a marked improvement. When, in reality... an impeller is only a tuning device.
With something like an impeller... there are WAY too many variables to know what's going to happen. If your pump, and impeller are perfect, and new... changing the impeller may not make much of a change. Also... on newer skis... they have spent their time to make better OEM impellers, and in the proper pitch. AND... in many cases... Skat-Trak, or Solas make the OEM impellers.
On the older skis... they would just put in an impeller, and not really focus on total performance. OR... the manufacture would focus on "Target Market" for data. So... if you have a mid 90's 3 seater... they are under pitched, to give you the ability to pull more weight, or a tube.
And finally... on the very old skis... they use to come with an aluminum impeller. They had a fat hub, and fat blades. Putting in a well constructed stainless impeller would make a night-N-day difference.
So... if you put a new impeller in your ski... and were expecting to have a 10 MPH jump... well... then you never actually read any post made here.
At the most... assuming you have a mid 90's ski... and the engine is in good shape (making full HP) then using a thin hub impeller (like a concord) with a little more pitch... then best you can expect is about 3 mph. But, if the engine is tired... then the added volume, and pitch may just bog the engine, and you won't gain anything.
Personally, I like Skat-Track "Swirl" impellers. They have more overlap, and fight cavitation better than any other impeller. In turn... they give great "out of the hole" performance... but they are known to scrub 1~2 mph off your top speed. But here again... if you pump is beat, you have a leaking shoe, a leaking D-shaft seal, and the engine is down on power... then you will have ZERO gain.
As a final word... since you only have 18 posts under your belt... don't come here, and complain about a performance part in general. If you want to make a complaint... then give EXACTS. (part numbers, compression readings, etc)
Oh... just an FYI... that polaris SL would have come from the factory with a Swirl.
That's my story... and I'm sticking to it !!
