The new ring SHOULD NOT be tight !!!!!!!!!
I can service my pump, and the parts just slide apart without any real problems. (maybe a little tap)
After this we will be able to also! LOL
Everything is clean, dried, primed and painted. I had a new can of Mercury Primer and a can of Phantom Black paint already! Thanks for that heads up!
I'll be ordering the anodes tomorrow and. . . and. . . A STEERING CABLE!
uke: It's really probably a good thing we did all of this work now! The cable separated at the crimp and the insides were rusty. We noticed the heim joint was cracked but I had planned to get that at Fastenal along with that bolt we broke off. But now I have to get a cable too. By the way I had read in another thread to use a 22mm crows foot to remove the backside stop nut for the steering cable but our front and back nuts were 7/8". I had pre-purchased the 22mm so I will return it and get a 7/8" crows foot or will we not need it now?
SO!. . .Before it started raining, again - ugh, I opened the cover up and climbed in the engine compartment and saw the panel (starboard side) that unscrews and provides additional access to the area where the cables run. I knew I'd find everything all neatly strapped together and in corrugated plastic cable protection conduit.
Dr Honda. . .Go ahead and give me your expert instructions for installing a new steering cable and shopping list please . . .
Would you spring for the OEM cable or would the SBT be sufficient? What about the anodes? Those little boogers are expensive. Can I get them somewhere else other than OEM Sea Doo or Mercury?
And . . .I was also thinking about putting the stator back on. The seal looks good and there was no water in it when I drained it but should that seal be replaced while we have it apart? For some reason in my mind I can't figure out how that seals around the drive shaft and doesn't get water in there. (Blonde moment) Or I'm just exhausted from working on this since Friday afternoon! :banghead:
Dr Honda. . .You keeping notes on all of my questions? LOL
atriot:
