Black creek cruzin
The boat has twin 717 engine..right motor blew last summer just had the dealer install a new sbt engine, and wear rings in the back as well as rebuilt carbs on both motors..Boat ran great for 2 weeks and now on start up it runs great and after 15 minuets it starts surging..from 6k rpm to 4k and back and forth. I personally pulled and replaced all spark plugs, opened up both carbs and sprayed down with carb cleaner, changed both the fuel filters by the fuel tank, ran compression test on both motors and they all read almost 150psi. boat is still surging..I have tried running with the fan on to help with air flow and still surging..I am out of ideas. Please help if there is anything else I can try..Also with the new motor the dealer told me to run twice the normal amount of oil..I think the last they told was with 15gallons of gas at a time mix with 35 ozs of oil..Could this be the problem? running to rich? I also put a can of seafoam in yesterday hoping to clear it up. Thanks for any and all help.
