Tri_CityMJ
Hello ALL,
I am having a fuel issue with my 1998 GSX ltd. Starts right up , runs fine until about 35 MPH or 1/3 of the throttle. If you punch the throttle it will die. If I slowly keep priming the plunger(primer) up and down it will get right up to 60MPH. So here is what I have done in the 2 months I have owned it. I first changed all of the gray fuel lines, removed and cleaned out the fuel selector valve, replaced the plugs, removed and rebuilt the dual carbs.I am using non ethanol fuel. Is it an air issue? maybe from the aftermarket primer that someone installed? Im not sure where to go from here. I had a guy look at it and he said one side of the coil was weak? Im not sure if that would affect the fuel delivery issue. sounds like another issue to me. Anyway I could use some help. Thanks MJ
