Lightning546
My ski won't start.
I was going to ride two days ago after not having rode my ski for 2 weeks. Installed the key and didn't get any beeps, didn't think anything about it as mine does that quite frequently. Pushed the start button and got one long beep.
Checked the battery with the multi-meter, read 12.68 volts.
Checked the fuses, none blown, checked the power at the solenoid, meter read 12.68 volts, tried shorting across the solenoid terminals, starter won't spin.
Bench tested both starters, they both work perfectly.
Ran the self test, 1 long and 1 short beep.
Pushed the start button, only get a click and 1 long beep and now I have to wait a few hours before it will allow me to enter the self test routine again.
Replaced solenoid, tried starting again, no joy.
Replaced starter, again no joy.
Put old solenoid back in, no joy.
Used multi-meter to check for a short between the solenoid and ground, dead short between wire going to positive terminal on starter and the ground wire.
Just checked old and new starters, dead short between the positive terminal and the starter housing, but when test probe is connected to the positive terminal bolt and starter housing instead of the nut I get 4.5 Mohms resistance.
Ski was running perfectly with the exception of the bogging which it has done since I bought it and had a new motor installed 5 years ago. Carbs are rebuilt every year, all fuel lines were replaced with reinforced coast guard approved marine fuel line and the fuel selector valve has been replaced.
